Thread: Wheel Bearings & Swivels - oil fed, double lip seals, packing, slotting and the rest.
    May 2003
    On The Road
    Guard Wheel Bearings & Swivels - oil fed, double lip seals, packing, slotting and the rest.
    Wheel Bearings & swivels - oil fed, double lip seals, and the rest.
    The double-lip seal is RTC3511
    Hub nut spanner is 52mm, can use a Toyota one in a pinch.
    Bearings -
    With pics
    http://www.aulro.com/afvb/projects-t...-tutorial.html
    Also with pics
    Convert RR+Disco Wheel Bearings to Oil Lubed?
    Oil lubed bearings -
    wheel bearings D1
    Seating hub seal -
    http://www.aulro.com/afvb/technical-...tml#post815316
    Front wheel bearings on early 110.
    Swivels -
    Including all of the above and more!
    Mysteries of the swivel
    Difflock tutorial, many pics -
    DIFFLOCK.com - Project 110
    One-shot grease and oil-fed bearings-
    One shot grease for wheel bearings?
    Grease nipples, drilling holes in stub axles to aid lubrication, discussion... -
    Rear wheel bearings for '93 Disco'
    How do you convert to OIL LUBED WHEEL BEARINGS?
    Pic here -
    Stub axle destruction, speedy sleeves, replacement-
    Wheel bearings, Stub axles and Ignorance
    Part numbers, seals, seals, more seals -
    Wheel bearings, swivel seals and hub seals.....Again.....
    http://www.aulro.com/afvb/discovery/...-bearings.html
    Phew.
    And another with some excellent pics.
    May 2003
    On The Road
    Slotted swivels for castor correction.
