Results 1 to 10 of 16
Thread: Td5 Engines, ECU's, studs, loom, head removal, FPR, Injectors changes, Alternators
    May 2003
    On The Road
    Anchor Td5 Engines, ECU's, studs, loom, head removal, FPR, Injectors changes, Alternators
    Links to AULRO posts that may fix your problem,
    read these first.
    May 2003
    On The Road
    Minor Service Procedure
    td5 service time
    Post 5.
    Broken head studs
    http://www.aulro.com/afvb/discovery/...uds-again.html
    warped exhaust manifolds..
    warped exhaust manifolds... - Australian Land Rover Owners
    TD5 Manifold Modification - Australian Land Rover Owners
    Fuel Pressure Regulator
    http://forums.lr4x4.com/index.php'showtopic=25537
    Fuel Pressure Regulator O ring fix
    TD5 Fuel Pressure Regulator
    wiring loom
    Wiring loom harness AGAIN!!! - Australian Land Rover Owners
    TD5 cutting out - Australian Land Rover Owners
    -td5-injector-loom-cheap-fix-once-all.html
    TD5 Injector Loom cheap fix once and for all
    Filters
    Which oil fiter?? - Australian Land Rover Owners
    Engine harness part numbers
    Disco TD5 Engine Harnesses - Australian Land Rover Owners
    Td5 Auxillary belts
    Defender Td5 Auxillary belt. - Australian Land Rover Owners
    "I obtained and tested a shorter belt that bypasses the ACE pump on my TD5 for emergency use. The original belt was 7PK1870 and the shorter one is 8PK1560 cut down to 7 ribs (7PK1560 equiv)."
    TD5 fuel filter change
    TD5 fuel filter change - Australian Land Rover Owners
    Oil Cooler Hoses
    Oil Cooler Hoses, now 3rd time in 10 years - Australian Land Rover Owners
    Turbo Elbow Hose
    Intercooler hi pressure side Elbow? - Australian Land Rover Owners
    Oil Pump Bolt
    Fender TD5 oil pump bolt
    Engine Mounts
    http://www.aulro.com/afvb/technical-...ounts-how.html
    http://www.aulro.com/afvb/discovery-...regulator.html
    TD5 Engine Mounts
    http://www.aulro.com/afvb/discovery-...ounts-how.html
    May 2003
    On The Road
    Exclamation head gaskets, sump gaskets
    May 2003
    On The Road
    Module concerns?
    TD 5 No guts no glory
    TD5 Head removal replacement
    May 2003
    On The Road
    Thanks to Disco_owner
    A VERY comprehensive TD5 engine description--
    http://www.aulro.com/afvb/parking-lo...d5-engine.html
    May 2003
    On The Road
    TD5 ECU swaps, tunes and numbers
    TD5 ECU Part No. Definition?
    Td5 ecu:How many reflashes?
    Which is which
    http://www.aulro.com/afvb/discovery-2/154383-discovery-2-ecu.html
    TD5 ECU's
    ECU swapping
    Step by step guide for swapping from MSB to NNN ECU’s TD5
    May 2003
    On The Road
    How to change a Td5 Injector
    May 2003
    On The Road
    TD5 Alternator Repairs
    Dropbox - Alternator tutorial.pdf
    TD5 Alternator Failure - Something To Check
    Guys, something to check if you suspect you have a failed alternator in any TD5, Defender, Disco or Range Rover. If you are getting zero out put to your batteries from your alternator, before rushing out and spending a fortune on a new one. Check you have brake lights operational. If not the likely culprit is a blown brake light fuse 10A. The alternator output to the batteries is also fed through this fuse, so if that goes you have no charge. A 20c 10A fuse was the solution.
    Had this last night and feared a new alternator required just before going to Broome. Only found the solution to this by accident when trawling the net. Go's to show check all the simple things first even if you dont believe they wil be relevent.
    TD5 Alternator parts
    Td5 alternator
    Alternator Removal leaving fan in place
    Changing a Td5 alternator without removing the fan.
    May 2003
    On The Road
    TD5 compression
